Injectors
Old Jan 13, 2011 | 06:58 AM
mule97's Avatar
Default Injectors
how good r the stock ones. iread one post and sombody says 03 injecters r junk is it true. ive always owned 12v. iam new to the newer cummins some advice please.
Old Jan 13, 2011 | 12:49 PM
haulitrite's Avatar
The consensus around here is they average 70,000-120,000 miles. Some owners get more miles on a set some get less on a set.
From what I have read there are two major factors in the life of injectors and pumps.
1) Buy quality fuel, poor quality fuel will cause excessive wear and premature damage.
2) Fuel filtration, a 2micron filter is a must for fuel system longevity. (Changing the filter every oil change doesn't hurt either).
Old Jan 13, 2011 | 09:19 PM
zach_west's Avatar
they are junk bt i guess mine lasted 175xxx
Old Jan 14, 2011 | 06:37 AM
mule97's Avatar
iam on 144xxx
Old Jan 14, 2011 | 08:37 AM
98dodgecummins's Avatar
if i get a good fil-teration system with a 2 micron filter and keep my truck stock will the injectors last a while.
Old Jan 14, 2011 | 12:36 PM
Id try some thing like this....
VP MAX Under Intake Filter System CR
Old Jan 14, 2011 | 01:09 PM
CountryGirl91's Avatar
I'm at 93,000+ miles and at start-up, it white smokes bad for a few minutes until I put it in gear and go. It also idles rough and misses.
I guess I feel better that it's common for them to go bad around that many miles but it's definitely not a great time to have to buy injectors now.
Some guy said to add some Stanadyne fuel additive and it will fix the problem. Sounds like a temporary fix to me but I guess I'll try it until I can buy some injectors. What threw us off was when he told my dad you can't replace nozzles on the CR...why couldn't you?
Old Jan 14, 2011 | 01:29 PM
steved's Avatar
Its not dirt as much as it is water...I lost my OEs at 145k, and I had been running 1u filtration for the majority of those miles. However, I picked up a load of water at one point (drained over a gallon of water from my filters) and I attribute that to their demise.
Old Jan 14, 2011 | 05:46 PM
i might buy the vp max under intake filter system cr.
does any one think that an 05 will have a apps mounted to the block. why is it on some trucks and not others.
Last edited by 98dodgecummins; Jan 14, 2011 at 05:46 PM. Reason: Automerged Doublepost
Old Jan 14, 2011 | 08:02 PM
mule97's Avatar
thanks every one for there advice lukesdiesel if u can get it let me know pm me. hopefully this damn snow gets the hell out of here i can start putting my hrs back in at work.
