will they fit??
Old Jan 13, 2011 | 03:05 AM
Big Andy's Avatar
Default will they fit??
Can I fit 35's on a dodge 2500 with a 2" levelin kit in the front? If not what's the biggest size that'll fit? Thanks
Old Jan 13, 2011 | 05:43 AM
monster12valve's Avatar
they will fit
Old Jan 13, 2011 | 09:19 PM
Big Andy's Avatar
Will they rub like hell though?
Old Jan 14, 2011 | 04:52 PM
5.9sledhead's Avatar
ya mine did but my shocks were out too so that didnt help at all. I have a 2" level too.
Old Jan 16, 2011 | 02:49 PM
c12vpwr's Avatar
i have 33 12.50s on my truck and it clears but there is no way i could put 35 on it and not rub
Old Jan 16, 2011 | 09:59 PM
moneypitk5's Avatar
Im running 315-75-16's, they dont rub at all on a 2" leveling kit.
Old Jan 16, 2011 | 10:02 PM
Red_Rattler's Avatar
High Tech Redneck
Depends on rim/tire combo
Old Jan 17, 2011 | 09:40 AM
line worker's Avatar
think you need a 10"rim w/ 4" backspacing
Old Jan 17, 2011 | 10:21 AM
guhfluh's Avatar
Depends heavily on rim offset. I have ~33's on my 2wd with only a very slight rub on the rear of the fender liner. I lifted it roughly 3/4" with spacers and no rub at all. The rims tuck more than normal "4wd" rims though. I believe they're 20x9" with -30mm offset. 0mm offset would rub like crazy. On a 4wd truck and lifted you will clear easily with the right offset.
Old Jan 17, 2011 | 12:33 PM
Gazoo's Avatar
So basically it sounds like it all comes down to the backspacing on the aftermarket rim you choose??? I ask because I have the chance to nab cheap set of 18x9 mamba M2rims wrapped in 325/60R18 Hankook MT's. Checked website and they are only made in 5.5 or 4.75inch backspacing. Will either of these work on my totally stock non lifted 02 4x4???? According to my calculations makes it roughly a 33.5 inch tire but 12.75 inch wide?
