turbo help
Old Jan 12, 2011 | 08:08 PM
ruffneck6969's Avatar
Default turbo help
i have a 93 bone stock gmc 2500 6.5 td i cant hear or feel the turbo kicking in when i pop the hood an give it throttle by hand the waste gate arm barely moves is there a way i can adjust this or free it up to move i have no gages as of yet any help would be great
Old Jan 12, 2011 | 08:53 PM
Crazy's Avatar
you won't see it move just setting and may not it these turbo where not loud because of the exhaust being 2.5" clog cat and muffler now like rest of us exhaust is one first thing we place with 3" down pipe with 4" back that wake up the motor and turbo will whistle
now waste gate works off vacuum there is no adjustment
How do I check to see if I have wastegate problems? A quick test would be, at idle, see if the wastegate rod is pulled up into the actuator housing. If it is, that is a good start. Now, pull on the rod, and see if you are able to move it. Pulled in means there is vacuum. Suction is good, but how much? If you are able to move it, then you may not have sufficient vacuum to maintain boost.
To really test the system you should get a vacuum gauge to verify readings - with engine idling you should have 26"hg at the vacuum pump and 15"hg at the wastegate, but the above 'pull-test' will show if you're in the ball park
Old Jan 12, 2011 | 09:09 PM
nice i will try that an see thank you an i want to change out the exhaust as soon as i get the money
also i thought the 93 didnt have a vacum i thought it was all mechanical
k did the pull test at idle it was pulled in an i can move it pretty easy to fully open but i do not see any vac lines anywere near the turbo
Last edited by ruffneck6969; Jan 12, 2011 at 09:09 PM. Reason: Automerged Doublepost
Old Jan 12, 2011 | 10:08 PM
Crazy's Avatar
ok not sure on the 93 let do some looking and let know
ok here i found out when it works of preset spring action if pull when idling it should pull right bad you right no vacuum the way realy know if working right is have boost gauge to make sure spring not week
Old Jan 13, 2011 | 09:37 AM
cool il have to get gages an check it out thanks for the info
Old Jan 13, 2011 | 09:43 AM
Crazy's Avatar
if you have exhaust leak you loose boost also you need tight exhaust and good clean air filter
Old Jan 13, 2011 | 10:01 AM
no exhaust leaks an a brand new filter in it i just dont really feel it when iam accelerating an hardly any smoke out the pipe so just wondering if its working right il just have to get a boost gaudge an see
Old Jan 13, 2011 | 10:04 AM
Crazy's Avatar
once you get gauge put in then you can make TM (turbo Master) where you adjust it 10psi boost but i would also put egt gauge also
Old Jan 13, 2011 | 10:14 AM
ok once i get all that how do you make a turbo master
Old Jan 13, 2011 | 10:20 AM
Crazy's Avatar
this good site show and tell you how
Make Your Own Mechanical Wastegate Controller
oh can buy one from heath for around $100.00
