air dog connect?
Old Jan 12, 2011 | 04:45 PM
jcrad's Avatar
Default air dog connect?
Can someone tell me where to connect my airdog to my ecu on 01 cummins. I cant find the connector.
Old Jan 12, 2011 | 05:37 PM
banditsdiesel's Avatar
to the ecu? what part are you connecting to the ecu?
Old Jan 12, 2011 | 05:57 PM
jcrad's Avatar
Default Airdog
The directions say to unplug the factory lift pump from ecm 2 pin connector and plug in airdog to that connector. I cant find the connector.
Old Jan 12, 2011 | 06:01 PM
Farmboy 2.0's Avatar
It should plug into the plug for the factory pump, and then to the battery as well. The Deutsch ecm plug should be the wires coming from the top of the factory oe lift pump and be about 5 inches long and should be located below and behind to the rear of the fuel filter canister.
Old Jan 12, 2011 | 08:21 PM
exactly what he said. unplug the factory pump and piggy back the battery relay harness. then i suggest pulling out the factory lift pump and fuel canister. it makes the side of the motor look much cleaner.
and scott if you have the 11 hole II injectors, watch them. ive talked with several ppl who have had them split the nozzel. and i can say as a fact it happens. it cost me a motor.
Last edited by banditsdiesel; Jan 12, 2011 at 08:23 PM. Reason: Automerged Doublepost
Old Jan 13, 2011 | 12:52 PM
Thanks Man.... Yeah mine are the 6x018's so far I love them
Old Jan 13, 2011 | 10:02 PM
ah i got you that what in mine now. coupled with the extreme dragon fire VP it make for some really nice hp. only think i have against the setup is the constant smoke. it never stops. idleing it smokes more than most of the guys around here at full throttle. just wondering if your does the same?
Old Jan 14, 2011 | 01:39 PM
Mine with the set up I have now is just a slight haze at idle and while driving. But im still running a stock vp for now til it takes a crap on me
Old Jan 14, 2011 | 04:36 PM
ya i could see that only being a slight haze then. conidering the pump i run is 140% more fuel than stock just from the pump. and its only a matter of time till a vp craps out. a stock one anyways.
Old Jan 14, 2011 | 04:38 PM
Yeah so far 160,000 and still going strong.
moneypitk5
Feb 12, 2015 11:01 AM
dawnrogerl
Price Quote - Request A Price
Jan 29, 2015 01:03 AM
dawnrogerl
Air Dog
Jan 23, 2015 03:09 PM
veggyoilkid
Nov 13, 2014 11:57 AM
veggyoilkid
Nov 10, 2014 12:39 PM
