Bd vs Denny T Fuel pin ?
Old Jan 12, 2011 | 01:52 PM
jguycj7's Avatar
Default Bd vs Denny T Fuel pin ?
Well the title says it all in terms of that seat of the pants feeling I was more impressed with turning my stock fuel pin than I am with my bd fuel pin . So is this a common issue for you guy out there ? Should I spend the coin again for the Denny T Or grind on the bully dog ? Any opinions would be a great help . Thanx again to every one!
Old Jan 12, 2011 | 03:56 PM
Billy D's Avatar
Denny T
Old Jan 12, 2011 | 05:59 PM
901stgen's Avatar
DENNY T!!!!!!!
Old Jan 12, 2011 | 06:21 PM
CARP's Avatar
"Old Smoky Power Pin"
Old Jan 12, 2011 | 07:24 PM
big bad diesel 416's Avatar
Site Sponsor
go with the Denny T i sell ALOT of them the BD pins are made of a lower quality and will gouge plus they dont ad as much power
Old Jan 12, 2011 | 09:07 PM
JBradley500's Avatar
I agree with the softer material. I like my DennyT and Dennis has done a stand up job but.... i don't think you can say a Denny T will make more power. I know my AFC lever is maxed out with 1/4" of fuel cone left (Appx. 1/2 diameter of the fuel cone). Anything deeper than that is just for looks.
Old Jan 13, 2011 | 04:53 PM
Rusty89Cummins's Avatar
dont waster your time with the BD pin. i had one in my truck until recently. for one i wasnt happy with the performance from it and the BD pin is a cheesy soft metal. the needle wore into it and actualy made notches on it and was causing the pin to hang up and not move. and that was with lube on it too. i still have to call up the company to complain about it. i can put up some pics of it if youd like.
you could probly grind the BD pin if you already have it but its still gunna be the same soft metal. go witha denny t or one of the M series pins.
Old Jan 14, 2011 | 05:21 PM
jguycj7's Avatar
Hey guys thanx for the advice . I just hate throwin money around if its not needed, But this bd thing has me really t'd off . On top of the power issue, it was oversized when i got it & had to put in in my drill & sand & pollish it till it fit . e mailed them about it & nada .
Thank you all again .......
Old Jun 1, 2012 | 03:45 PM
CUMMINStagetcha19's Avatar
Between the denny t and M&H's fuel pins, which is better?
Old Jun 1, 2012 | 10:09 PM
BC847's Avatar
I've run both brands.
M&H, there's a greater selection pending your intentions.
