new turbo
Old Jan 11, 2011 | 10:13 PM
cummins95's Avatar
Default new turbo
here it is
still workin thru the break in period. took it for about a 60 mile trip keepin it under 15psi, which was pretty easy considerin the main road has 4 inches of snow on it right now. another 90 miles n i can open her up. i cant believe how loud this thing whistles, i love it. installation wasnt too bad, had some trouble with the oil return line but we got it.
thanks to KT performance!
Old Jan 11, 2011 | 10:31 PM
captain_stabbin's Avatar
Old Jan 13, 2011 | 05:31 PM
cummins95's Avatar
well i got 200 miles on it now so i decided to give her a little bit today. WOOOOOOWWWW this is a whole new truck! i am definitely happy with it. i can get it started spoolin by 1300 rpms no problem, n then its goodbye. cant wit til spring time so i can get er on the rollers n see what the ol rust bucket is makin
prolly oughta start a new thread for this but does anybody run ladder bars n tow? it seems to me there would be some binding issues...
Old Jan 13, 2011 | 05:40 PM
Flight911's Avatar
Default new turbo
Break in period? How do u properly break one in. I thought you just let it idle for a few mins and take off
Brandon
Old Jan 13, 2011 | 08:51 PM
cummins95's Avatar
it said to put 150 miles on it under 15psi. i went 200 just to give it a little extra
Old Jan 13, 2011 | 09:24 PM
94 12valve's Avatar
break in is pretty simple, add oil before you start the truck add oil to the turbo, run it for a few mins, and go have fun. thats right from BW
Old Jan 13, 2011 | 10:27 PM
12valvetater's Avatar
If you go off your driveline angle you won't have a binding issue with bars. Think about it, they wouldn't want the slider to constantly be working or it would wear it out before you knew it.
Old Jan 14, 2011 | 01:39 AM
EasternAggie's Avatar
Is this the D-tech 62/65/12 listed in your sig? Plannin on gettin the same turbo this summer.
Old Jan 14, 2011 | 06:06 AM
cummins95's Avatar
yep its a dtech, the 5x12's seem like the perfect amt of fuel for the turbo. if ur gettin 5x14's u might wanna go with somethin a little bigger.
good point. im gonna build some then
Old Jan 14, 2011 | 09:04 PM
hmmmmm. well the reason I'm wanting to go with the 62/65 is because I want something fast spooling so I can throw a HT3B or S400 series underneath it later and use it as a primary in a set of twins. and I want the 5x.014's so I can provide plenty of fuel to the twins when it comes time for that.
you think with the 62/65/12 and 5x.014's I could run a #100 plate or so about 3/4 forward to help take some of the fuel out?
