241transfer to 205
Old Jan 11, 2011 | 08:35 PM
pukie370's Avatar
Default 241transfer to 205
i have a 97 with nv4500 and 241 transfer. im wondering if i can junk for a 205? which 205 do i need, i know the first gen goes wrong way. so did dodge but 205s in 2nd gens. or do i have to use special adapters. i think toe 205 is a wonderful transfercase. any input appreciated.
Old Jan 11, 2011 | 10:48 PM
Moparpower440's Avatar
As far as i know there isn't a 205 that will just bolt up in place of your 241. If your serious about the swap you can check out Advanced Adapters. They should be able to set you up with the proper adapters to make it work. You'll also need to find a Drivers side drop 205 from a Ford. Why are you trying to swap the 241 out?
Old Jan 11, 2011 | 10:51 PM
pukie370's Avatar
i have never liked chain drive transfer cases, and the 205 is easier to to hook up pto.
Old Jan 11, 2011 | 11:08 PM
The 205s are strong and are a popular choice in the off-road world. I'm sure there is a way. You might also post over on Pirate4x4.com I'm positive someone on there has done what your trying to do
Old Jan 12, 2011 | 01:11 AM
93_Fummins's Avatar
http://http://advanceadapters.com/pr...6/50-0220.html
I was considering an NV4500 and NP205 combo in my Fummins and this is the kit I was looking at. You may have to ask Advance Adapters if it works with the Diesel NV4500 (the site doesn't show this kit when you choose Diesel NV4500 HD in the dropdown). Worth a look if you are sold on the NP205 conversion...
Old Jan 19, 2011 | 04:27 PM
deerefanatic's Avatar
I got a friend that runs a Ford NP205 in his 95 dodge with a 5 speed.....
Personally though, in the truck pulling world, NP205's blow up quicker than the 241DHD's do...... I think most of the bad rap for chain t-cases comes from the cases developing leaks, and running dry.... Just my theory.... I'd sooner step up to one of the NP271's they use behind the common rail... They're friggin huge!!!
Oh, and my buddy got his kit from advance adapters
Last edited by deerefanatic; Jan 19, 2011 at 04:27 PM. Reason: Automerged Doublepost
Old Jan 19, 2011 | 07:37 PM
12valvetater's Avatar
Gear drive transfer cases are for the birds. Ever wonder why all gear drive transfers have iron cases? The reason is why they don't last under power.
Old Jan 19, 2011 | 09:07 PM
Well, gear drive t-cases in general arent all bad..... You should see the profab units that major hp guys run for sled pulling..... But gas and diesel..... They are ALL gear-gear drive.... And billet aluminum cases.....
But yes, gear drive has major spreading forces between the gears, where chain drive will have a pulling force between them.. But compression strenght is usually stronger than tensile.....
Old Jan 19, 2011 | 11:24 PM
kazairl's Avatar
271 Nuff said. People who think a standard gear drive transfer case that was originally behind a 180hp motor are stronger than the modern chain drives are ignorant.
Old Jan 20, 2011 | 03:09 AM
Imacummin's Avatar
If you decide to sell your 241 dhd im interested in buying it, just let me know. Thanks
