Death wobble
Old Jan 11, 2011 | 06:36 AM
c0zgrove's Avatar
Default Death wobble
Hey guys could sway bar end links cause a death wobble all the tie rods and ball joints have been replaced and the death wobble gets really bad sometimes but the end links is the only thing that hasn't been replaced
sent from my G2 @ 1.516ghz
Old Jan 11, 2011 | 07:27 AM
Whit's Avatar
Site Mascot
death wobbles is caused by a combination of loose parts but if you have anything in the fron end that is sloppy it needs replaced, also I would add a steering atabilizer to the gig........................I got mine from DSS
Old Jan 11, 2011 | 08:59 AM
c0zgrove's Avatar
Default Re: Death wobble
Well I have an aftermarket stabilizer on it but I noticed slop in the steering gear box and sway bay end links so I'm gonna replace the gear box and try new end links do you think that could be my problem
Old Jan 11, 2011 | 09:08 AM
Whit's Avatar
Site Mascot
sounds lik it yes.............dont hesitate this is very important
I am told the gearbox is adjustable for slop but I have never messed with one before
after all the new parts get a frontend allignment too........go toein slightly to eliminate wander
Old Jan 11, 2011 | 09:30 AM
c0zgrove's Avatar
Thanks whit I'm going to try that this weekend ill post the results
Old Jan 11, 2011 | 12:23 PM
coors_man_2005's Avatar
on my 08 with 6'' lift i got death wobble and it ended up being my tie rod to pitman arm that will give you slop in steering also and my buddies truck ended up being his shock bushings dont know if that will help you any but just a shout
Old Jan 11, 2011 | 06:35 PM
DslDeamon's Avatar
id check your control arms to had a buddy that had the death wobble and thats what it turned out to be just putting in my 2 cents
tbirdz24v
Aug 22, 2015 06:41 AM
SMatyac
Nov 11, 2014 12:49 PM
