2nd gen turbo
Old Jan 10, 2011 | 08:43 PM
BIG NIG's Avatar
Default 2nd gen turbo
i gots an ATS Aurora 4000, probably less than 5K miles on it
has MST compressor housing, spools faster and flows more.....so ATS told me
blah blah blah
AURORA 4000 TURBO SYSTEM - 1994-98 DODGE 12-VALVE 5.9L CUMMINS
Part# 202-940-2164
The Aurora 4000 Turbocharger System Features and Benefits:
Increased torque
Increased power
Lower EGTs
Increased efficiency
Everything's included for a smooth installation
One of our most popular turbochargers, the Aurora 4000 turbo system is the perfect solution when looking for a turbo for your Dodge Cummins® diesel truck that provides solid power, and can still easily be driven every day. You get a moderate spool-up time, solid midrange power and boost pressures up to 48 PSI. And there is no need for head studs with this turbo.
on there site for $1795
$750 + shipping no trades
Old Jan 15, 2011 | 03:05 PM
EasternAggie's Avatar
what are the specs on this turbo? compressor wheel size, turbine size, exhaust housing etc.
Old Jan 15, 2011 | 03:25 PM
RAW's Avatar
RAW
This is for a primary in a compound set up, or to be run as a single?
Old Jan 19, 2011 | 05:48 PM
PRTdiesel's Avatar
would you sell it for any lower?
Old Jan 26, 2011 | 11:39 AM
truckinbiker's Avatar
What size is the inducer? turbine? If it is 66-62 I want it, though do you have any pics?
Old Jan 27, 2011 | 11:55 AM
Hightech_Redneck's Avatar
its a 64mm..... i almost bought one a few months ago to see that they did away with those housings cause of issues... you can put a regular housing on it
Old Jan 27, 2011 | 12:22 PM
the Aurora 4000 is a 64/70 and comes in 12, 14 or 16cm exhaust housings.
Old Jan 28, 2011 | 10:04 AM
muhasamituffie's Avatar
Still have the Turbo? Very interested... if you still have shoot me a text 1-306-276-8083 ... will this fit on a t3 ped?
Old Jan 28, 2011 | 10:35 AM
aarons91cummins's Avatar
Would my hx 40 be able to spool it for a compound setup?
Old Jan 28, 2011 | 11:14 AM
12vcummins96's Avatar
no need it will work fine as a single too small for a compound setup
