dragging starter
Old Jan 10, 2011 | 07:37 PM
joey's Avatar
Default dragging starter
Started my truck this morning and the starter hung up and kept dragging. I had to disconect the battery leads to kill it. My question is it in the starter or key switch or something else. thanks in advance.
Old Jan 10, 2011 | 07:46 PM
94 12valve's Avatar
starter contacts there easy to change and cheep check out Larry B's
Old Jan 10, 2011 | 07:50 PM
Red_Rattler's Avatar
High Tech Redneck
Dont do that too many more times or you'll burn up your fuel shutoff solenoid!
Starter FAQ
Old Jan 11, 2011 | 07:35 AM
joey's Avatar
ok so i need to rebuild the starter. So the solinoid contacts are pitted and stickin.
Old Oct 5, 2011 | 03:57 PM
MANDIE77578's Avatar
Default Can you tell me what ended up being the problem
My 2001 Dodge 2500 Cummins just started doing the same thing this past Sunday. It was pretty scary, we also had to take the cables off the batteries to get the truck to turn off. Did it end up being the starter, ignition switch or something else? Thanks.
Old Oct 5, 2011 | 06:19 PM
aguilar_15's Avatar
That post is way old. But most probable it was the starter contacts.
Also, MANDIE77578 this is the 12 valve section, you want the 24 valve.
Welcome to DB!
leocanuck
6.0L Performance
Sep 27, 2015 06:05 PM
klein444
Jun 20, 2015 11:48 PM
ajwright64
Feb 17, 2015 10:08 AM
james2562
Feb 5, 2015 09:05 PM
nevadagramm
Oct 17, 2014 07:59 PM
