dash
Old Jan 9, 2011 | 03:37 PM
12valvers's Avatar
Default dash
can someone please inform me how to take the dash out my truck, im trying to get at the main vacuum line that makes all my vents work cuz they aint workin at the moment, ive taken out all the screws and bolts i can see but i can seem to firgure out how to get at the front of the hvac stuff.
please and thanks
Old Jan 9, 2011 | 03:46 PM
12Vdodge's Avatar
what year of truck are you working on? fill out your sig. man. Assuming this is a 94-98 year truck, theres a nut on the left and right side near the kick panel area (if i recall correctly) that you loosen. Our dashes are designed pivot downward on these two hinges and then assuming everything is disconnected it can then be pulled out as a whole unit revealing the heater core and all the vaccum lines.
hopefully this helps ya and others will chime in as well
Old Jan 9, 2011 | 04:05 PM
12valvers's Avatar
its a 98 and the whole unit consists of what exactly?
Old Jan 9, 2011 | 04:36 PM
Red_Rattler's Avatar
High Tech Redneck
Same concept applies for the newer dash. But u have to have the bezel off radio out unhooked drop the steering colume to the floor then after the lower bolts by the kick panal are removed the whole dash should roll towards the seats
Kinda shows the lower mount but besure to undo both sides not one like this pic shows...
Old Jan 9, 2011 | 04:53 PM
When youre in there make sure you replace your heater core
Old Jan 9, 2011 | 08:50 PM
tiremann9669's Avatar
The vacum supply line goes in from the engine compartment right by the heater hoses on the firewall. I'd make sure it's not an underhood problem before pullin the dash cuz it's a PIA
Old Jan 10, 2011 | 09:49 PM
gone ropin's Avatar
mine was a collapsed hose under the hood,, pulling the dash sucks and the old ones crack way too easy when they get older
mike350fordpower
Jul 17, 2015 08:51 AM
casper83
Jun 29, 2015 07:37 PM
Brushout
Audio Equipment/Electrical
Mar 18, 2015 10:54 PM
Andy81
Jan 28, 2015 02:53 PM
FELTONMICHAEL
Dec 28, 2014 01:09 PM
