91 first gen overdrive help please!
Old Jan 9, 2011 | 01:57 PM
cummin91's Avatar
Default 91 first gen overdrive help please!
hello i was hoping someone could help me with my overdrive trouble shooting.. it will go in and out is it my tranny slipping or what.. also my speedometer goes up and down didnt no if it could be some sensor linked together? i was told to get a throttle position sensor that i can adjest when if locks in to overdrive someone help me!
Old Jan 9, 2011 | 10:48 PM
Shoe's Avatar
I have this problem. My plan is to instal a potentiometer. Way cheaper.
Old Jan 10, 2011 | 06:44 AM
cummin91's Avatar
What is that and where can I purchase one?
Old Jan 10, 2011 | 08:47 AM
jeffandjess4806's Avatar
lots of guys build there own but look here...seems fair priced
1st/2nd Generation Dodge OverDrive Kit *91.5-98 12v* [DNR] - $37.99 : Zen Cart!, The Art of E-commerce
Old Jan 12, 2011 | 08:02 PM
snakebite2004's Avatar
overdrive solenoid....look in the stickys, there is a wiring diagram of the transmission which includes the overdrive solenoid....had lots of problems out of mine and tried to eliminate everything before iwent into the transmission, needless to say, i went into the transmission and all is good. as for your speedo i can't help you there...maybe its missing a tooth on cable gear? not sure how these trucks are set up on speedometers so dont quote me on that.
Old Jan 12, 2011 | 09:24 PM
cummin91's Avatar
Ok so i f I don't replace the overdrive soleniodand just get that delete kit is that ok? Or will it mess something up?
Old Jan 12, 2011 | 10:55 PM
backwoodsW250's Avatar
On your speedometer the sensor may be loose or have gone bad mine did this it is on the transfer case on the drivers side. A new sensor is should be about 35 bucks at your local parts house
Old Jan 13, 2011 | 01:13 AM
jwirth's Avatar
First thing you need to find out is why your speedo is acting up. Your overdrive is not going to work correctly if it is going up and down. Find the problem and fix it RIGHT. My plan is to instal a potentiometer. You have to love it when you buy a used truck someone has rigged together. I'm having to same problem with my speedometer.
Cdog121
Nov 16, 2015 01:49 PM
FF131
9
Mar 26, 2015 07:06 AM
Tory4
For Sale
Feb 1, 2015 08:33 PM
CGwill
Jan 26, 2015 02:10 AM
Canadiancummins93
8
Dec 10, 2014 09:03 PM
