Fuel Pressure Swinging From 60-100 psi??
Old Jan 9, 2011 | 05:16 AM
Cowboy Cadillac's Avatar
Default Fuel Pressure Swinging From 60-100 psi??
On the drive in this morning I noticed my fuel pressure guage (added) seemed to be reading 100 psi. The next stop light I got to I shut the truck down and restarted it and it came back to 60 psi where it normaly stays. Thoughout the rest of the drive in the pressure would swing form 60-100 and seemed to be some what associated with the position of the skinny pedal on the right. It was a little cold here this morning (18 F) and was wondering if that may be what is causing the swing or could this be a sign of an up comming problem?
Any suggestions welcome,
Thanks in advance.
Old Jan 9, 2011 | 07:27 AM
deucer's Avatar
Engine temp. might have something to do with it. If the engine has not reached proper operating temp. it could require additional throttle to respond which equates to higher pressure demand.
Old Jan 9, 2011 | 08:47 AM
Mdub707's Avatar
The pump is regulated by a spring, so there is no more demand for higher or lower fuel pressure, it is whatever that spring will hold. It should be 55psi plus or minus 5. My guess is you possibly have a grounding issue with the gauge. I highly doubt you're seeing 100psi of fuel pressure, you will start popping o-rings if that was the case.
Old Jan 9, 2011 | 12:13 PM
ranger518's Avatar
yea what Mdub707 said it sounds like a gauge to me.
Old Jan 9, 2011 | 01:27 PM
That could be the case I was behind the fuse block the other day messing with the upfitter switches. Could have possibly tweaked something the wrong way?
Old Jan 14, 2011 | 06:45 PM
Thanks to all for the great info. I have been keeping a closer watch on it and My guess is it is probly something to do with the guage or associated components. I haven't had a chance to open it up to know for sure though. The truck still runs as good as it has been and I am seeing no other issues except for the fuel guage being stuck on 100 psi.
Old Jan 20, 2011 | 05:10 AM
Question UPDATE??
Still no change in the situation. I have checked my wiring connections and all seem good. I have been in touch with the AutoMeter folk and they are starting to show some intrest.
Anyone have an idea about what OE equipment may be causing this problem, if any? And how to go about checking that equipment?
I am Stumped...
W.R.
Old Feb 2, 2011 | 06:50 AM
Problem Fixed.... It was the sending unit after all.
Old Feb 2, 2011 | 07:21 AM
Mdub707's Avatar
Good to hear. I have a ISSPRO EV2 fuel pressure gauge, and it swings pretty drastically too, not as bad as yours though. However I'm reading fuel pressure about 36" past the end of the heads down on the vegistroke manifold. Not sure if my pump just can't keep up or what.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
