Need some advice on my tranmission
Old Jan 9, 2011 | 01:57 AM
moneyman_09's Avatar
Default Need some advice on my tranmission
So i just had my a 518 transmission rebuilt and i am not happy with it at all i had the shop install a transgo shift kit and a dacco single clutch billet torque converter. I told them i wanted firm shifts but i cant feel it shift at all i can hear it. seams like it shift to soon and is iffy getting into over drive it acts like it's struggleing to pull my 6000 pound camper when i no it should be no problem the shop said i had a one year 12.000 mile warranty but fails to return my calls or evan say that they did the work. I think it has something to do with the kickdown cable or the valve body.
Please any advice or if you know someone good with transmissions in northern indiana help me out.
Old Jan 9, 2011 | 03:33 AM
cumminsblazer's Avatar
Will it down shift when u stab it?
Old Jan 9, 2011 | 06:23 AM
Billy D's Avatar
Burn that place down
Old Jan 9, 2011 | 11:06 AM
Does not downshift, has a brand new kickdown cable it will downshift up hills then takes awhile to shift back into overdrive.
Old Jan 9, 2011 | 11:26 AM
RSWORDS's Avatar
Adjust your Kickdown cable
https://www.dieselbombers.com/1st-ge...djustment.html
Then your TPS.
https://www.dieselbombers.com/1st-ge...ensor-tps.html
Let us know if that makes any difference.
Old Jan 9, 2011 | 12:03 PM
dieseldawg's Avatar
clutch converter?? i dont know shiet about trannys but arnt those for lock up 47rh/re's ??????????
Old Jan 9, 2011 | 12:14 PM
no its a non lock up tc dacco claims 89% on the one in my truck i believe. tps is what i was thinking could be causing this
Old Jan 9, 2011 | 12:20 PM
RSWORDS's Avatar
It is crazy easy to adjust and makes a world of difference. That thread will walk you right through it.
Old Jan 9, 2011 | 07:15 PM
Thanks alot the tps was not working correctly
Old Jan 9, 2011 | 07:16 PM
RSWORDS's Avatar
So its fixed? Shifting better and all?
Good to hear.
