transmission line pressure
Old Jan 8, 2011 | 06:37 PM
Jeff M's Avatar
Default transmission line pressure
does anyone know what the trans cooler line pressure for a 47re is?
Old Jan 8, 2011 | 07:18 PM
turbo20psi's Avatar
At idle it is 45-65psi and at WOT it is 90-100psi.This is with a stock VB.Aftermarket VB will be more.
Old Jan 8, 2011 | 07:54 PM
Jeff M's Avatar
cool! thanks!
Old Jan 8, 2011 | 07:57 PM
Default Re: trans line pressure
The BD VB I had in my 01 made around 135 max.
Luke
Old Jan 8, 2011 | 08:46 PM
RAW's Avatar
RAW
Wow, and to think the idiots at A1 told me it is only 4 or 5 PSI. Then again, they also built a transmission with zero clearance in the forward clutch.
Old Jan 8, 2011 | 09:55 PM
Russ Roth's Avatar
The OP asked about trans cooler line pressure not what is run throughout the tranny. The trans cooler has much less pressure than the tranny under load. I don't really know what it is but not very much. The cooler in front of the radiator just has rubber hose connections to the steel line. Mine leaked and I cut the metal connection off and replaced it with a screw clamp and has held fine for more than 3 years.
RR
gp98
May 11, 2015 09:04 AM
|WYG|SS
May 7, 2015 04:57 AM
mcompton1973
Feb 11, 2015 12:00 PM
BubbaDT55
Dec 7, 2014 08:52 AM
motormayhem
Nov 16, 2014 02:13 PM
