apps???
i thought me apps sensor was bad so i took one of my buddys 01 and tried it that wasnt the problem so then i put it back on his truck and now it says its bad i followed the instructions on recalibrating it you know unhook batteries for a half hour then put them back on and turn the key on and press the pedal to the floor and back up and start .then the code comes back
Have a look at this. It needs to be adjusted properly otherwise you can have issues.
https://www.dieselbombers.com/24-val...ting-apps.html
ok got it adj but it has a little dead spot right as you let the clutch out its not much like around 900 rpm i put the apps in the right setting maybe its just time for a new one idk
The APPS will were out over time.A constent holding patten will were it out over the years.These work great. AFTERMARKET APPS THROTTLE POSITION SENSOR ('98.5-'02)-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
burndiesel
10
Feb 7, 2023 01:15 AM
Craigdegolier
Jul 20, 2015 04:46 AM
