CR injector Reliability?
Old Jan 8, 2011 | 12:01 PM
98dodgecummins's Avatar
Default CR injector Reliability?
if i leave my 05 cummins stock do i have to worry about injectors going out or do i still need to get a better filteration system?
Old Jan 8, 2011 | 02:03 PM
Default Re: CR injector Reliaability?
I would run a 2 Micron fuel filter
Luke
Old Jan 8, 2011 | 02:32 PM
Can I run a 2 micron fuel filter on a factory system if so what filter should i get?
Old Jan 8, 2011 | 02:41 PM
THE REDDOG's Avatar
WIX 33585XE
I been told is a 2 micron filter
$21.99
Old Jan 8, 2011 | 02:51 PM
ok thanks
i looked up the wix filter and it is only a 7 nominal micron filter.
Last edited by 98dodgecummins; Jan 8, 2011 at 02:51 PM. Reason: Automerged Doublepost
asylum's Avatar
Do changing injectors make a difference?
Old Jan 8, 2011 | 06:02 PM
i dont know?
Old Jan 8, 2011 | 07:23 PM
dangerous1965's Avatar
Put a filter pre Cp3 2 micron and you will have no more injector problems from fuel.
these injectors are good for about 60k there are some exceptions out there! But on average! The 2 micron will extend that life past 100k! So it's worth doing! I'm running a semi fleetguard FF5319. Good for 30k easy just change the primary stock filter every oil change!
Old Jan 9, 2011 | 09:10 AM
what do you mean by putting a filter pre cp3.
Old Jan 9, 2011 | 09:42 AM
Pre= before Just put it inline!
