STARTS RIGHT UP, DIES, THEN STARTS HARD
Old Jan 8, 2011 | 03:03 AM
92 BUCKBOARD's Avatar
Default STARTS RIGHT UP, DIES, THEN STARTS HARD
I HAVE AN ISSUE WITH AN 01. It starts right up and runs for about 5 seconds then dies. it will start again but it starts real hard. no codes are present. anyone have any ideas? lift pump was just replaced but it did this before .
Old Jan 8, 2011 | 03:07 AM
biged681985's Avatar
what lift pump did u put on the truck?
Old Jan 8, 2011 | 03:20 AM
he just replaced it with another stock lift pump.
its not a fuel issue. the wait to start light comes on for just a couple seconds on the initial start then it wont come on again when u start it the second time. i will change the relay in the power dist. box and see if that changes the situation. if it doesn't then i will check the relays on the fenderwell and the grid itself.
Last edited by 92 BUCKBOARD; Jan 8, 2011 at 03:20 AM. Reason: Automerged Doublepost
Old Jan 8, 2011 | 07:36 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
try to notice when you have it running if your tach is working right. im wondering about crank sensor if you see the tach not working right.
Old Jan 8, 2011 | 08:12 AM
it could be the cam sensor. the 01-02 go off the cam senor for the tach.
idk bout the wiat to start deal, but the starting up, then dieing and hard to start back up sounds like a fuel issue to me.
Old Jan 8, 2011 | 10:05 AM
diesel pap's Avatar
Old Jan 8, 2011 | 10:56 AM
Air in fuel system or VP44
Old Jan 10, 2011 | 12:01 PM
kerley's Avatar
That's what my 98.5 did, it was the vp44.
Old Jan 10, 2011 | 06:31 PM
1999 CTD's Avatar
vp44!
go to thoroughbreed diesel! GREAT prices fast shipping!!!!!!
sounds like the vp44! but have some1 test it first cuz its an expensive fix
go to Thoroughbreed diesel GREAT prices and fast shipping! hope u get it figured out bud!
Old Jan 10, 2011 | 06:43 PM
Rustin's Avatar
If none of those things are the problem, you might want to look into the sending unit in the tank. Some times those things get clogged and cause trouble. Does the fuel gauge mess up intermittently? Just another Idea if it is not electrical or a fuel pump issue. Realy the best way to test is with a pressure guage. If the electrical is not the problem. I agree with the reast of the members that it sounds like a fuel issue.
Excursion73
Sep 9, 2015 09:20 PM
DC_DC41
Jul 16, 2015 09:56 PM
dshopex4
Chevy/GMC Duramax 01-04 LB7
14
Apr 15, 2015 09:40 PM
cummins828
Nov 29, 2014 10:01 PM
