48RE 2nd gear slipping?
Old Jan 7, 2011 | 04:58 PM
bluetj's Avatar
Default 48RE 2nd gear slipping?
I have a friend with an 06 Dodge, under 100,000 miles, only mods are intake, muffler removed, and a Smarty POD. The Smarty was just installed last month. When it shifts into 2nd it slips bad till it hits 3rd. no slipping in any other gears. If you shift into neutral at a stop sign it goes through the gears fine after take off, but if you just stop and take off it slips 2nd. So bad he has to take a different route to work because of a hill after a stop sign. We adjusted the bands on Xmas day and he said it seemed to help but its not anymore. Any help is greatly appreciated! He is about ready to pull it out for a rebuild but want to make sure its not something simple or electrical frist. Thanks
Old Jan 7, 2011 | 05:41 PM
dangerous1965's Avatar
He wasted the band! bummer got to drop the tranny to fix that!
Old Jan 9, 2011 | 12:42 PM
bluetj's Avatar
Ok, thanks for the reply. I think he's taking it to a shop to get checked out. Had a few people tell me to change pressure sensor and shift selenoid, so I think he might try that first.
Old Jan 9, 2011 | 07:57 PM
That's possible too! Let us know what it turns out to be!
Old Jan 31, 2011 | 05:48 PM
TeckJohn's Avatar
electronic governor is mounted on the driver side of the transmission and when it goes bad it will make it stay in 2nd gear longer and shift hard into 2nd. try to swap with a friend to see if it fixes your problem and if it does then go buy one
corksil
Aug 2, 2015 10:19 PM
Jun 4, 2015 09:30 PM
aoutlaw95
Mar 3, 2015 09:02 PM
rtbcoop
Nov 29, 2014 11:33 PM
Oct 18, 2014 10:52 AM
