Oil in water on 2nd Gen 12v
Old Jan 7, 2011 | 04:39 PM
Flight911's Avatar
Default Oil in water on 2nd Gen 12v
I just put a s300 turbo or a 64/71/14 and I have no idea what it boost cause my gauge only goes to 30psi. I have water in the oil and pressure build up in radiator. HeAd gasket????
Old Jan 7, 2011 | 04:46 PM
daveO's Avatar
More than likely. Could also be a crack in head or block, or a leaking oil cooler.
Old Jan 7, 2011 | 11:41 PM
bean farms's Avatar
mine done the same thing took my head off and had it re-built and checkt for cracks and they said it was good put it all back together and it still does it so ether the machine shop didnt check the head and its junk or my block is busted not sure i would like to find out for sure but i dont now were the blocks crack at most of the time does yours have much blow by maybe yours is just a head gaskit best of luck to ya
Old Jan 8, 2011 | 12:55 AM
biged681985's Avatar
id put money on u lifted the head with ur turbo. u didnt mention head studs, so if u dont have them, then u need to be getting u some. also, u need to get ya a bigger boost gauge so u can adjust ur waste gate. good luck
Old Jan 8, 2011 | 03:01 AM
captain_stabbin's Avatar
boost should be st at 42 lbs from factory
Old Jan 8, 2011 | 04:19 AM
97cummins's Avatar
you should get a look at the oil cooler.
Old Jan 8, 2011 | 07:15 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
make sure you deck your head when you have it off.
Old Jan 8, 2011 | 07:30 AM
Flight911's Avatar
Alrite. I was leaning towards head or head gasket cause a week after I put that bigger turbo on it this happened. I'm as going to check oil cooler. Yeah I'm going to go back with head studs as well. Thanks. I'm just glad all of yall didnt say oh ya your block is just a boat anchor now.
Old Jan 8, 2011 | 07:32 AM
Flight911's Avatar
If I'm gunna deck my head and put 60# springs can't I put bigger values as well?
Old Jan 8, 2011 | 08:33 AM
Flight911's Avatar
Wheres a good place to order some head studs, gasket set and an oil cooler
