Help Please
Old Jan 7, 2011 | 03:48 PM
adub12valve's Avatar
Default Help Please
I was trying to put a lock up switch on my truck and when I turned the switch on, everything in my cluster wont work. I unhooked it and nothing will still turn on. The truck runs but it wont shift. Any advice would be useful, thanks Andrew
Old Jan 7, 2011 | 03:56 PM
Rustin's Avatar
You cut the wrong wire some where. Are you sure you rehooked everything back?
Old Jan 7, 2011 | 04:02 PM
Yeah everything is taken off and back to normal. And I used a splicer to hook them up so I wouldnt have to cut anything.
Old Jan 7, 2011 | 04:06 PM
Flight911's Avatar
Default Help Please
How do I start a new tread with my iPhone
Old Jan 7, 2011 | 04:28 PM
Could not tell you
Old Jan 7, 2011 | 04:34 PM
Flight911's Avatar
Default Help Please
This suxs
Old Jan 7, 2011 | 04:39 PM
Anyone have anything?
Old Jan 7, 2011 | 04:50 PM
turbostang7's Avatar
check all your fuses, sounds like one is blown
Old Jan 7, 2011 | 05:03 PM
I just did and all are good
Old Jan 7, 2011 | 05:12 PM
even the ones under the hood? also check all grounds make sure that they are clean and tight. what kind of wire taps did you use too?
