My first post ever
Old Jan 7, 2011 | 01:05 PM
jguycj7's Avatar
Default My first post ever
First THANK YOU ALL !!! You've been my greatest asset w/ my truck .
Now my ? . I put in a bd fuel pin after turning my factory pin . Seems the power went to the top end & my top speed went up . But All the power from my bottom end is gone & it only seems to smoke at full throtle . Any sugestions on tuning the factory pump to get the power don to lower to mid range level ? O & the mid range of my right foot seems almost like a dead spot .
Old Jan 7, 2011 | 01:21 PM
RSWORDS's Avatar
first...
Which pin did you turn?
To tune your pin put a small amount of greese on the face of it, run the truck around for a while getting it up to full boost a couple times. Pull teh pin and look at the witness mark to see how much travel you are getting. Adjust you smoke screw so that it just gets to teh deepest part of teh pin under full boost.
Old Jan 7, 2011 | 02:27 PM
jguycj7's Avatar
So the smoke screw will act as a depth gauge to keep the pin at the deepest part of the cut . If i may ask one more part of the equation . will it help at this point to adjust the star wheel all the way down or should that wait till the smoke screw part of adjustment feels to have better response ?
Old Jan 7, 2011 | 04:21 PM
RSWORDS's Avatar
The smoke screw and star wheel really wont help you with any of that. I would adjust your smoke screw so it is working proper and then if you want you can bottom your star wheel. Look in the sticky and you will find a good thread about tuning the pump.
Old Jan 7, 2011 | 05:14 PM
jguycj7's Avatar
I'll go to now thanx for the help .
