dies under boost
so righ twhen i get up to 7psi the truck dies. i know this is when my rack is suppose to slide but for some reason the truck shuts off around that psi. any thoughts?
The 'rack' you're referring to... talking about the fuel plate/afc rack?
Anyway... does it completely shut off (DIE), or just stutter and lose power? Because my truck had a similar situation when the fuel heater bowl pre-filter screen was clogged AND the fuel filter was clogged. After changing those 2 items out it ran like a champ!
My advice would be to double check those easy/cheap items and move on from there. if nothing else, you've got a fresh fuel filter in there, and that can never hurt!
But in neutral, the truck isn't under a load, and without boost the fuel rack won't move forward. Revving in neutral will use far less fuel. I would check your fuel pressure and go from there.
does your truck bog out and die the more you get on the throttle im having similar issue with my 97 just replaced fuel filter and lift pump next step was gonna be checking the fuel heater screen and overflow valve then move to the tank not a diesel mechanic so just goin down the list as i can
offroad00
24
Oct 23, 2014 03:28 PM
