save yourself the headache
Old Jan 6, 2011 | 07:27 PM
blackcloud21's Avatar
Default save yourself the headache
If ur vaccum pump or ur power steering pump happen to go up no big deal. To Take old ones off but do ir self a favor when pulling the old pulleys go to n parts store and get the special tool to pull them. Do not do it with conventional pullers the pulleys r thin n will bend. I spent three hours last night hearing n beating my vac pulley. and putting the pulley on the new pump uses Tue same tool. Or if ur a lil tool savy there are threads in the center of the shaft of the pumps a bolt with the correct threads and a couple of washers on top the pulley just start the bolt and hit it with an impact gun a little bit at a time. Don't go hogwild as ull mess up the threads they r weak. But if u take ur time ull b fine. For the record there r no bolts that hold pulleys on pumps. Theu r just pressed on. Also these pulleys r. Junk yard part. If u happen to bend ur old one. U can get new ones from ford but they want like 60 bucks for. One. So while its not a hard job to do its also not hard to mess stuff. Up. Also do not use a vice or press to put new pulleys on ull press the shaft of the pump out the back of the pump as tjhey r weak parts. So take ir time and keep that coal Rollin.
Old Jan 6, 2011 | 08:37 PM
gunman41mag's Avatar
Moderator
THANK YOU FOR THE INFORMATION
Genos Garage
Genos Garage
Sep 4, 2015 10:32 AM
Genos Garage
Genos Garage
Jul 6, 2015 12:35 PM
jkidd
Diesel Auto Power
Apr 23, 2015 09:04 AM
Adam Sanders
LB7 Performance
Jan 21, 2015 06:57 AM
