View Poll Results: Which T-handle does everyone prefer!
B&M
22.22%
Hurst
55.56%
Other
22.22%
Voters: 18. You may not vote on this poll
T-handle shift knobs!!!
Old Mar 24, 2007 | 09:12 PM
CumminsCrazed's Avatar
Default T-handle shift *****!!!
Well guys, im stuck up the middle between which T-handle shift **** to get for my cummins! I like the B&M company more than the Hurst company, as ive always run the B&M shifters and had VERY good luck with them. However, the most well known T-handle shift **** on the shelves is the Hurst unit. Im also trying to deicde on the comfort between each handle while shifting. Heres is a pic of both and please vote for your choice on the poll then tell me why you chose that shift **** and why, if your running it etc.
Old Mar 24, 2007 | 09:20 PM
MRaynor's Avatar
Just moved you here, thought you might get a little better exposure, and more help.
Old Mar 24, 2007 | 09:39 PM
ok, wasnt sure, we need a gen. diesel forum like everyone else, where all diesl brands/generations can come together
Old Mar 24, 2007 | 09:41 PM
NukleusX's Avatar
zach i couldnt honestly tell you what one to get as i dont have any experience with them, but they both look cool
Old Mar 25, 2007 | 12:44 PM
I have 5 Hurst replies and one other reply, i need some input as to WHY the hurst is better over the B&M...
Old Mar 25, 2007 | 01:05 PM
gstanfield's Avatar
I voted "other" as I refuse to use the T-handles. The trouble with a T-handle is it will promote you driving with your hand on the handle. Resting your hand on the shifter while driving is about the worst thing you can do to your manual transmission. The weight of your hand and the vibrations of driving will wear stuff out pretty quick. I've read about this in several owners manuals of different cars and from practical application find it to be true.
My Dad has over 300,000 miles on a New Process trans that stick clicks audibly and shifts just as it did when new. NO slop whatsoever. He shifts with just two fingers and never rests his arm on the shifter. I know of several folks with the same trans who ride with their hand on the ****. Their **** was worn smooth and the trans sloppy to shift after only about 50-60 thousand miles. My previous trucks were manual trans trucks and by shifting carefully and never resting my arm on the shifter they shifter like new when I got rid of them, normally after 60k-100k miles.
Just a word of advice, get the T-handle if you want, but do not use it as an arm rest, you'll regret it if you keep the truck for a long time.
With that said, I like the looks of the B&M better
George
Old Mar 25, 2007 | 01:13 PM
That is a very good piece of advice. Resting your hand in the shift **** wears out the synchros in a hurry.
Old Mar 25, 2007 | 01:35 PM
i never heard of such a thing......i rest my arm on the arm rest and sometimes dangle my fingers on the shifter, but never put any weight on it.....
Old Mar 25, 2007 | 01:48 PM
Benjamin's Avatar
Bombardier
other... as i've had the B&M on a 5 speed van before it is not as comfortable as you would think.... if you make it comfortable for the 1-2 shift then the geometry will be off between your arm, wrist, hand, and the shifter for the other shifts and will get old quick..... i'd stay with a ball style shifter if it were me..... those handles above are only somewhat usefull for a floor mount auto shifter that goes forward and backwards....
Old Mar 25, 2007 | 01:52 PM
gstanfield's Avatar
Good point Benjamin, the angle will only fit just right at one or two locations, not 7 (6 speeds plus Reverse)
See, you learn something new everyday, aren't forums great
George
