manuel trans cracked
Old Jan 6, 2011 | 05:17 PM
wide open's Avatar
Default manuel trans cracked
i got a 2003 cummins with a nv 4500 and it is cracked what should i do?
Old Jan 6, 2011 | 06:54 PM
haulitrite's Avatar
Step 1
Buy a new (new, refurbished, used)one. If you do get a used transmission don't expect there to be many (if any) usable internal parts in your old one.
Step 2
Install the new transmission right behind the engine.
Old Jan 7, 2011 | 05:42 AM
turbostang7's Avatar
first off where is the crack, if its not too terible yet it could be fixed and you wont have to buy a new trans
Old Jan 7, 2011 | 09:48 PM
wide open's Avatar
well i got a new main case to day and every thing in my trans is in really good shape so now it is time to swap everything from my bad case to my new case. it was cracked right behind the bell housing bolt on the driver side about 3 inches starting at the top.
Old Jan 7, 2011 | 10:25 PM
so it was just on the bellhousing part, not into the trans yet? you can get that fixed, they can weld a crack like that up fairly easily and pretty cheap
Old Jan 7, 2011 | 10:32 PM
wide open's Avatar
it had just started leaking fluid. and the part that needed welding was cast iron. but thanks by the way
Old Jan 7, 2011 | 10:41 PM
oh gotcha, yeah if its leaking its pretty much done, but cast iron can be repared as well but a little more spendy.
Jake9473
Jul 22, 2018 08:19 AM
Rabbitjbu
Jul 28, 2015 06:03 PM
cutthroatxxx
Mar 19, 2015 09:26 PM
pv89sj
Oct 12, 2014 02:45 PM
Pyrohigh
Oct 11, 2014 07:59 AM
