speedi sleeves
Old Jan 5, 2011 | 09:28 PM
zjohnsonua's Avatar
Default speedi sleeves
I've worn two grooves in the spindle finish on my rear axle where the bearing seal sits and have an annoying leak. I need one of these sleeves to fix it. I've called every parts house in town and either we have a lot of bad parts guys or these things are hard to track down. Does anyone know a part number for the repair kit or know the dimensions of the spindle ODs? Thanks guys
Old Jan 7, 2011 | 08:49 AM
biged681985's Avatar
i dont know nothing bout it but here is a bump so maybe some one else will see it that does
Old Jan 7, 2011 | 09:17 AM
kazairl's Avatar
I bought my last speedy sleeve at a bearing place. If you get the part number off the seal the guy at the bearing store can look up what size speedy sleeve to use.
Red_Rattler's Avatar
High Tech Redneck
Dana 70 od of the spindle is 1.957
Try a heavy duty truck shop and see if they can track down the correct size.
Old Jan 7, 2011 | 09:22 AM
Uncle Bubba's Avatar
Talk to these folks. If they don't have them, they will know where to send you to. Home
You may also try a post in the price quote thread to see if any of our vendors can help out.
Old Jan 7, 2011 | 09:55 AM
High Tech Redneck
The more i think abt this are you talking about the outer axle or pinion yolk? Because if your tryin to go on the outer housing your not gonna find one
Old Jan 7, 2011 | 05:20 PM
zjohnsonua's Avatar
I'm talking about the actual rear spindle that the axle slides through, wheel bearings roll on, and provides the wheel sealing surface. I know they make one for the D60 and a bunch of others...which is why I find it odd that this is such a strange part to get.
These guys may have answered my question. It seems the best solution is to just to install the seal at a different depth to get the seal to ride on fresh metal.
