banks power!
Old Jan 5, 2011 | 08:52 PM
blowinsmoke12v's Avatar
Default banks power!
just cruising through banks site and i was curious to if i should even waste my time with putting on the BIG HEAD ACTUATOR...will i see a difference and any thing bad about it?
Old Jan 5, 2011 | 09:28 PM
bulldog77's Avatar
This one is cheaper
BD Power - Product: Adjustable Wastegate Kits
Or get a boost elbow if you want some more boost out of your turbo.
Old Jan 5, 2011 | 10:11 PM
FastCR's Avatar
the stock actuator will hold quite a bit. I pulled the bigger actuator off a junk turbo and put it on and got more out of it. I believe the big head is a nice product but you can probably find something cheaper easily for an hx35.
Old Jan 10, 2011 | 06:36 AM
I don't wanna put a boost elbow im making almost 50 pound of boost already on hx35 Soo ill probably blow it :/
Old Jan 10, 2011 | 08:57 AM
Pyro690's Avatar
You use the boost elbow to limit your boost. It doesn't increase what you have.
Old Jan 10, 2011 | 11:09 AM
94 12valve's Avatar
is your wastegate hooked up? if it is that banks product won't help ya you need to either cross drill the wastegate or get a bigger housing
Old Jan 10, 2011 | 10:07 PM
FastCR's Avatar
or a turbo. 50psi out of an hx35 is some really hot air. its about CFM.
Old Jan 10, 2011 | 11:28 PM
Red_Rattler's Avatar
High Tech Redneck
The big head makes like 32psi
Old Jan 11, 2011 | 12:51 AM
93_Fummins's Avatar
^ You sure about that? I was under the impression that the boost elbow limited the pressure going to the wastegate actuator thus manipulating it to open later resulting in more boost for a longer duration throughout spoolup...
Old Jan 11, 2011 | 12:53 AM
High Tech Redneck
You are correct, it delays the opening of the wastegate
