No start
Old Jan 5, 2011 | 08:31 PM
heavy hauler's Avatar
Default No start
A friends truck died the other day. He left out of his driveway and when the truck shifted gears (auto) it cut off and will not start back. Code on the dash is p1693. Took injection pump off and had the codes pulled on it and no codes. They wanted $150 to put it on the bench and test it and if they had to rebuid it it would be 1200. I can get the same pump for $1050. Was wandering if the electronics could have gone bad. I have a Hot Rod pump that the shaft seized up on but the electronics are still good. Can I put the electronics for the hot rod pump on the stock pump? or should i look for a different problem or replace the whole pump
Old Jan 7, 2011 | 08:54 AM
biged681985's Avatar
yes the electronics could have gone bad. as far as u swapping the electronics over, i wouldnt try it myself. u may be able to send it to a pump shop and have them do it, but dont qoute me on that
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
