Fuel/IP Question 6.5 1996
Old Jan 5, 2011 | 04:43 PM
cmbelau's Avatar
Default Fuel/IP Question 6.5 1996
If there is no fuel at the injectors, (and fuel filter has been changed and fuel is flowing at the filter vent and the drain in the front of the engine, does it mean the pump is weak or bad or are there other issues to check?
Thanks
cb
Old Jan 8, 2011 | 02:05 AM
biged681985's Avatar
i moved your thread for beter exposure from the 6.5 guys bump to the top also
Old Jan 8, 2011 | 08:11 AM
Crazy's Avatar
could be bad PMD and befor say it bad do these few test first
are you getting fuel at T-Valve with key in just on pos you get study stream fuel also check for fuel right at the IP input if you got juel there next step take fuel shut off solenoid ans see if the plumger moving with turning key on and off also check all grounds and clean they play big part with these trucks
Blake35
Jul 25, 2015 03:44 PM
Radioking1777
Jun 9, 2015 04:13 AM
F1nch
Mar 24, 2015 12:15 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
cummins Pride
Dec 31, 2014 12:58 PM
