oil filter smh
Old Jan 5, 2011 | 07:22 AM
-maverick-'s Avatar
Default oil filter smh
Went to go change the oil this morning on my 96 12v oil filter would not budge. first time changing the oil since i had the truck. Tried everything I put a screw driver thru it out of desperation to get it off. But the filter collapsed and now all thats left is the top of the filter. It is cross threaded on there bad i can get it to spin but she willnt bite the threads i tap on it when spining it i have tried everything. So the help i need from you guys is where do i get a new set up where the filter screws on i need that whole piece. thanks fellas !
Old Jan 5, 2011 | 08:05 AM
Dallas Flywheels's Avatar
I would go to the Cummins dealer for parts as they are usually cheaper than Dodge. When you put it back together ALWAYS put a film of oil or grease on the o-ring on the filter, it makes it easier to get off the next time. Good luck.
Old Jan 5, 2011 | 09:53 AM
country_boy's Avatar
i had the same problem with mine. i took a big pair of chanel locks and got ahold of the top of the filter and spun it off
Old Jan 5, 2011 | 10:29 AM
Whit's Avatar
Site Mascot
wide mouth filter pliers are the best ever, adjustable too, pinch it right at the top where the metal is doubled and rolled
Old Jan 6, 2011 | 07:42 AM
-maverick-'s Avatar
i always oil the o- ring but the previous owner must not have. I tried everything i cant get her off its stripped and will not grab the threads no matter what i do.
tried the pliars no luck. i can spin it but she has nothing to grab.
if its bad doing the oil i cant wait till i do the fuel filter
Old Jan 6, 2011 | 08:37 AM
Have you tried a strap wrench?
Better yet, the vice grips with the chain on them (again put it as close to the double rolled lip as possible)
That or a big flat blade screwdriver (a good sharp one) and a hammer. Put the screwdriver on the double rolled lip at the top and use the hammer to turn the filter.
Or get a new filter head.
Old Jan 6, 2011 | 08:54 AM
Red_Rattler's Avatar
High Tech Redneck
Cummins dealer for the new part. But since the filer edge hangs out past the hub I'd take a hammer and flatblade screw driver and deform the lip down all the way around. It might deform it enough to grab new thread or enough that it might slid off. Other way you well past the point of no return and it's worth alil more to try to wreck it then give up.
Old Jan 6, 2011 | 10:16 AM
-maverick-'s Avatar
when all else fails use the air hammer got it off and the threads are fine thank god just the filter threads are effed
soco
Jul 27, 2015 06:06 PM
helton87
For Sale
Jun 3, 2015 02:36 PM
Bob V
Apr 6, 2015 11:02 PM
jhprice
Mar 29, 2015 09:36 PM
Moparpower440
Jan 24, 2015 06:58 PM
