o5 raptor 150 install, broke down and got questions
Old Jan 5, 2011 | 02:21 AM
jakesnake_sxr's Avatar
Default o5 raptor 150 install, broke down and got questions
im getting another fuel module canister tomorrow and starting again. my question how does the canister get the fuel, the factory pump apperars to draw fuel through a red valve in the bottom of the canister. i dont see the draw straw pulling the valve open. So is it the return line that keeps the canister full of fuel in low tank situations.
ive been down since sun and ive really got to get this truck going again. any help would be awesome.
Old Jan 5, 2011 | 10:00 PM
dangerous1965's Avatar
A little more info here! You have a raptor 150 right? You gutted the intank pump right? You put the draw straw in the gutted housing right? There is no return on the raptor it is inside the pump. However post rail return does go back to the tank. So what are you asking about a canister?
Old Jan 6, 2011 | 10:36 AM
i managed to get it up and running yesterday. i bought another fuel module canister/intank lift pump assembly, with the new one in hand i was able to fix the old one. eveything seems to be working fine. thanks for your help.
Old Jan 7, 2011 | 10:43 AM
You can't use a raptor and a in tank canister "lift pump" under max fueling the raptor will be fighting "starving" for fuel
Old Jan 7, 2011 | 10:52 AM
i gutted the old lift pump canister, and have the return line running in there. ran the truck for about an hour on 1/8 tank and havent had any problems thus far. Havent ran it wot yet, but if i run into issues atleast i got an idea.
Old Jan 7, 2011 | 08:47 PM
Default Re: o5 raptor 150 install, broke down and got questions
You needed a Vulcan Draw Straw
Luke
Old Jan 8, 2011 | 09:46 AM
once i start having probs i will do the draw straw, for now im done. i dropped the tank on day one then it still wasent right so i pulled the bed. So for now i could care less to mess with it. thanks for the info bub
