4in turbo back and stock boost
Old Jan 3, 2011 | 09:36 PM
91cumminER's Avatar
Default 4in turbo back and stock boost
I recently added a 4in turbo back to 5in tip..a few mods to intake and such...anyone know what boost pondage my 03 5.9 common rail is pushin?
Old Jan 4, 2011 | 07:18 AM
Here_Have_A_Bullet's Avatar
Should be no more than 20 PSI with stock turbo with no wastegate mods.
Old Jan 4, 2011 | 05:28 PM
CountryGirl91's Avatar
I have an '06 and it's just straight-piped, with MBRP cat delete pipe, all on the stock 4" and no mods. Today, we just put a gauge to it and I'm making 28-30.
Old Jan 4, 2011 | 05:53 PM
Dodge4829's Avatar
06 and 03 have different turbos 04.5 is when they changed
Old Jan 4, 2011 | 05:59 PM
Wow, thought the wastegate opened up at 20 psi? Guess I was wrong, I had already modified my turbo on my 97 before I put a boost gauge.
Old Jan 5, 2011 | 04:12 AM
I didn't think it would make that much either. How much boost can it take being all stock?
Old Jan 5, 2011 | 05:49 AM
Other than turbo work and a torque plate, my 97 was stock and I was pushin 41 psi with no issues.
Old Jan 5, 2011 | 06:24 PM
BriteWhiteRam's Avatar
38psi is the max your going to get before the turbo is out of its Map, run any more boost and your going to be over speeding the turbo and making extra heat that will rob hp from you
Boost is a measurement of pressure resistance, the more boost, the less air your getting out of you engine..... on a stock turbo less boost isnt a bad thing, as long as your doing all you can to get the air in and out of your engine efficiently your going to be doing the best you can
just remember more boost doesn't always mean more power
51Hudson
10
Aug 5, 2015 12:32 AM
diesel pap
Mighty Diesel
Jun 26, 2015 10:26 AM
hockeypuk
Apr 30, 2015 09:50 AM
wyoborn&bred
Nov 25, 2014 06:35 PM
GreenDieselF
Oct 20, 2014 02:05 PM
