Where to tap in for boost gauge?
Old Jan 3, 2011 | 10:12 AM
jeffandjess4806's Avatar
Default Where to tap in for boost gauge?
I picked a boost gauge and need to find where to tap into to make it work
Old Jan 3, 2011 | 10:29 AM
Whit's Avatar
Site Mascot
Genos Garage sells a boost bolt or you can drill and tap into the intake horn
Old Jan 3, 2011 | 12:21 PM
1stGen1990's Avatar
on the intake side of the head behind (towards the cab) the injection pump is a plug that you can take out and put a fitting in there and that works perfect
Old Jan 3, 2011 | 01:19 PM
hiboy_76's Avatar
i used the plug in the intake too
Old Jan 3, 2011 | 01:51 PM
stodg73's Avatar
Look for the silver/black sensor. That is the easiest place to put the boost sensor. There is a 1/8"-27 plug in there.
Old Jan 4, 2011 | 11:21 AM
Found it...what kind of boost should i see on my 92 all stock other then removed the muffler.
Old Jan 4, 2011 | 11:59 AM
stodg73's Avatar
Well, if it is like my dad's '93 was, you should see anywhere from 0 to about 15 psi. He hardly got over 12psi, even pulling heavy loads.
Old Jan 6, 2011 | 09:17 AM
92smokinscummins's Avatar
my 92 i can hit 25psi under full acceleration, and the wastgate has more to give
huntman7
Sep 4, 2015 04:49 AM
MrCat4974
Mar 23, 2015 11:30 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
450r racer
Nov 14, 2014 05:11 PM
scottxmorris
Oct 8, 2014 02:14 PM
