nv4500 tailshaft
Old Jan 3, 2011 | 01:18 AM
c12vpwr's Avatar
Default nv4500 tailshaft
im looking to do a manual conversion in my 96 but i need to know if i can use a 4wd trans and put a 2wd tailshaft on it to make it work
Old Jan 3, 2011 | 10:04 AM
12vcummins96's Avatar
not without tearing the tranny apart
the 4wd output is shorter than the 2wd you will need to swap them out
Old Jan 3, 2011 | 12:39 PM
FastCR's Avatar
you'd have to change output housing and mainshaft. There is no output shaft.
Old Jan 3, 2011 | 12:57 PM
thanks for the clarify i meant to say that but had output on the brain
Old Jan 3, 2011 | 08:47 PM
K.Materi's Avatar
i have a 2wd tailhousing and mainshaft out of an nv4500. if you want it shoot me a pm.
Old Jan 4, 2011 | 02:15 AM
pukie370's Avatar
i will trade you 2 weel for 4 weel shaft and tail housing. but changing is a major teardown.
Old Jan 4, 2011 | 02:03 PM
Chevy355mark's Avatar
honestly your better off just getting a 4wd setup with the transfer case and just let the transfer case be there for if you ever wanted to convert to 4x4. when you buy the trans from a salvage yard its gonna cost about 100 bucks more to get a 4x4 one with the t-case vs a 2wd unit.
Old Jan 5, 2011 | 12:59 AM
c12vpwr's Avatar
if its that big of a tear down ill just buy a 2wd trans bc i never plan on going to a 4wd so i dont want to do that
Old Jan 5, 2011 | 01:32 AM
FastCR's Avatar
if you don't plan on doing a conversion, I'd recommend a 2wd trans if you can find one for a comparable price. I swapped mainshafts for a different reason, but in the end it was some money. I'm always an eff it I'll give it a try myself guy, but on that i still paid a professional to press in most of my bearings and adding that up by the time i was done I must have spent at least $300. The nv4500 is a simple transmission, but all that stuff is spinning fast under a lot of load. If your a machinist I'm sure you could do it no problem, but without the specialty tools you won't be feeling 100% about it when its done IMO.
taweste
Sep 10, 2015 09:16 PM
klu408
Price Quote - Request A Price
Apr 26, 2015 07:28 PM
Robert hawkins
Feb 23, 2015 08:06 AM
dezeldoc
Wanted To Buy (WTB) - Used
Jan 4, 2015 11:12 PM
CumminsMan2.0
Dec 11, 2014 04:57 AM
