injector problem
Old Jan 2, 2011 | 11:01 PM
bean farms's Avatar
Default injector problem
I've got a injector with a return line bolt hole stripped and I was wondering if I could use the top half of my stock injectors with the bottom half and springs and shims off the stripped injector. The stripped one is a 5x14.
Old Jan 3, 2011 | 12:17 AM
blazier18's Avatar
i wouldnt see a problem i guess sac and voc nozzles in a different body wouldnt hurt anything
Old Jan 3, 2011 | 11:54 AM
94 12valve's Avatar
you can do it ... would be a good idea to get them repoped before you reinstall it tho
Old Jan 4, 2011 | 08:42 AM
shortbusdriver's Avatar
It is a good idea to get them all popped checked and adjusted because only popping and adjusting one injector is not a good idea when all the other injectors may also be popping low.
