Getrag Shifter
Old Jan 2, 2011 | 10:26 PM
mdemco's Avatar
Default Getrag Shifter
I have a 93 with the Getrag. I can take my shifter and swing it side to side, hits the dash on either side of the truck. I can kind of get it in gear but it is a pain. Do I need to pull just the shifter or the whole top plate to try and find the source of this issue? Anyone know where to find a manual to do this?
Thanks!!
Old Jan 3, 2011 | 12:19 AM
901stgen's Avatar
https://www.dieselbombers.com/1st-ge...60-getrag.html Click the link
Old Jan 3, 2011 | 09:20 AM
mdemco's Avatar
I saw that the other day, thanks. The link in that thread for the manual is dead, the exploded view link worked but its small enough I cant tell what I am looking at in regards to the shifter.
Old Jan 3, 2011 | 02:30 PM
big bad diesel 416's Avatar
Site Sponsor
https://www.dieselbombers.com/1st-ge...2-i-found.html
Old Jan 3, 2011 | 03:29 PM
mdemco's Avatar
Thanks, that will be great if I need to pull the tranny and rebuild it. Interesting the manual shows nothing about removing the shifter and states to replace the entire shift cover if any parts are worn.
Anyone know if my issues can be found in just removing the shifter or do I need to pull the trans, mine cant be the first to do this. I have been searching this site and google looking for people with a swinging shifter but have not found much.
Old Jan 4, 2011 | 08:13 PM
timdale's Avatar
There are two bolts that connect the handle to the actual shift arm of the tranny. The shifter handle has a piece of metel crimped at the bottom were it bolts to the shift arm. That crimp (that has rubber in it for an isolator) was really loose on mine, causing a similar problem like you have. I just pulled the handle off and smacked the crimp a couple times with a 2lb
2gCummins
Jul 22, 2015 11:34 PM
RedChevy44
Apr 21, 2015 05:47 AM
cdpowers
Jan 23, 2015 01:42 PM
Cummins75
Dec 10, 2014 12:17 AM
wvwelder89
Sep 28, 2014 02:23 AM
