Diesel fuel in antifreeze....?
Old Jan 2, 2011 | 05:14 PM
HeavyChevyDMAX's Avatar
Default Diesel fuel in antifreeze....?
my buddy has a 2001 dodge cummins 6bt, 24 valve cummins and hes gettin diesel fuell in his antifreeze, anybody have any idea, hes thinkin injector sleeves?
Old Jan 2, 2011 | 05:46 PM
RAW's Avatar
RAW
Injector o-rings, maybe. Injection pump shaft seal is a possibility as well.
Old Jan 12, 2011 | 09:29 AM
blue24valvecummins's Avatar
i don't think it would be o rings or the shaft seal then it would dump fuel into the oil. do a coolant system pressure test and check for a cracked cylinder or head gasket. i don't believe they have sleeves did't see any when i put my injectors in.
Old Jan 12, 2011 | 11:42 AM
01_cummins's Avatar
id say headgasket may be split. that happened to my dads cummins and he fixed it and had no more troubles with it
Old Jan 12, 2011 | 05:48 PM
banditsdiesel's Avatar
24 valves dont have sleeves on the injectors its molded in the head. a head gasket would either put oil in the antifreeze or antifreeze in the oil. not fuel in the antifreeze. for that to happen the head would have to be cracked either at the conector tubes or the overflow returns. thats really an odd problem, ive never heard that one. just make sure it is fuel and not oil.
Old Jan 12, 2011 | 05:51 PM
Horns's Avatar
This would be my guess.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
Dec 2, 2014 03:10 AM
