Lift pump issue
Old Jan 2, 2011 | 07:02 AM
ozzking93's Avatar
Default Lift pump issue
I didnt know where to place this so im sorry if its not in the right place.
i have a 1995 12v 3500 cummins,and for the past few weeks maybe a month or two ive been having starting problems.
if you let it sit overnight it acts like it lost its prime and you have to crank and crank and then it will start,well everyone kept telling me to replace the overflow valve and i did and it still does it.
once youve started it,it will start first hit everytime,but once you let it sit overnight it acts like the fuel has bled back and you have to crank it to get it to start.
now i believe its the lift pump, but i was wondering instead of buying another lift pump can i just buy a raptor 100 and not worry about the mechanical lift pump? or do i have to remove the mechanical one?
any help would be appreciated
Old Jan 2, 2011 | 08:07 AM
Dallas Flywheels's Avatar
Check the supply and return fuel lines. It sounds like a leak and it is losing the prime and letting the fuel run back. Mine did it and I have replaced the return line twice now. Cured the problem.
Old Jan 2, 2011 | 08:28 AM
ozzking93's Avatar
alright ill check for leaks as soon as i can get it to stop raining. i dont know where to start, i guess under the hood would be the first choice.
Old Jan 3, 2011 | 01:26 PM
jtonasket's Avatar
Default Starting Problems
Mine is doing the same thing and has drained both my batteries trying to start the damn thing. I have found a small leak in the rubber line going into the fuel heater but I dont know the part # to get it replaced. When I try to start my truck know it tries to start but now it seems like Im not even getting a charge. Im going to replace both batteries but any help would be appreciated.
Old Jan 3, 2011 | 05:05 PM
ozzking93's Avatar
i think i found my leak,i went to put some oil in it after running it and noticed the fuel injector lines at the ends on the pump ontop where the dvs go looks like they were wet with diesel, dont remember how many looked wet but i will replace them tomorrow and see.
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
