Oil Smell
Old Jan 1, 2011 | 10:16 AM
waldo's Avatar
Default Oil Smell
I have a 2004.5 Cummins 5.9 it had 74K mi when I purchased it, it now has 85K mi. i am getting a strong oil smell. I have not seen oil on the garage floor or added any oil between changes, I am not seeing any smoke or feeling pressure when the oil cap is off, there was a very small amount on the slobber tube. The truck is in great shape and doesen't show signs of rough treatment, looks new and very clean and tight. anyone have any ideas on where to start on finding a solution.
Old Jan 1, 2011 | 10:51 AM
dangerous1965's Avatar
Are you in a enclosed area? What kind of oil are you using? Is it a engine oil smell or maybe a diff oil? Engine oil really doesn't smell BUT gear oil really smells if you over filled the diff that may be it!
Old Jan 1, 2011 | 11:18 AM
waldo's Avatar
No, it is when I am driving it and stop or slow down,I switched from Rotella to Valvoline premium blue. It may be diff oil I am trying to find out. Really like the truck, has tons of power. Thanks, the smell is really strong it could be the diff. oil
Old Jan 1, 2011 | 05:51 PM
tiremann9669's Avatar
Sounds like you have a slight oil leak thats gettin on the exhaust and burnin, could be as simple as the valve cover gasket. Or it's the turbo
Old Jan 1, 2011 | 07:24 PM
wildbill's Avatar
Or worse, got a valve guide or seat. Only way of telling is have all 6 cylinders leak tested.
Old Jan 1, 2011 | 08:22 PM
waldo's Avatar
no leaks that I can find, looked in under hood and underneath the truck, no oil on floor. Had it to two different shops, still no answers.
Old Jan 27, 2011 | 05:09 PM
kylemckay's Avatar
mine smells like engine oil if you fill it up high on the safe line if you only go half way up the safe on the dipstick you don't notice it?
Durtyd09
Nov 11, 2015 01:43 PM
rocanater
Ford Powerstroke 08-10 6.4L
Sep 29, 2015 04:38 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
coors_man_2005
Dec 15, 2014 10:23 AM
