What upgrade next?
Old Dec 31, 2010 | 06:55 PM
oldduallyfart's Avatar
Default What upgrade next?
I just finished installing a raptor 100 from Alligator performance and want to know what you guys suggest next.Im looking to improve fuel effieciency and hp without harming trans.thanks for your ideas.(im trying to upload pics of raptor install)Really wasnt too hard to install except dropping tank.But that wasnt bad using jack.
Old Dec 31, 2010 | 06:58 PM
Heres pics.
Attached Thumbnails What upgrade next?-100_1105.jpg   What upgrade next?-100_1102.jpg
Old Dec 31, 2010 | 07:10 PM
01quadcab's Avatar
and edge comp and don't tap the pump wire. also a good set of gauges or a quad adrenaline/edge juice with attitude
Old Dec 31, 2010 | 07:14 PM
I hve been reading what you guys say about programmers.The edge comp is a mild upgrade?And when you say dont tap pump what does that mean?
Old Dec 31, 2010 | 07:20 PM
RAW's Avatar
RAW
The Comp is mild to wild. Taping the pump tells it to deliver more fuel without the ECM telling it to
Old Dec 31, 2010 | 07:46 PM
quad adrenaline/edge juice with attitude?This is a chip and module(digital gauge) correct?
I dont know,i see 1slow24 posted today he installed an edge comp and it ran a little bit and died.That doesnt sound too good.
Last edited by oldduallyfart; Dec 31, 2010 at 07:47 PM. Reason: Automerged Doublepost
Old Dec 31, 2010 | 07:50 PM
RAW's Avatar
RAW
If an injection pump is already weak a fueling box will kill the IP quicker.
Old Dec 31, 2010 | 08:15 PM
Oh,okay.How can you tell if you injection pump is weak?I did install a low pressure led till i could afford a gauge or module but that just checks uplift pump,right?
Old Dec 31, 2010 | 11:09 PM
cap's Avatar
cap
Basically you really need two things to get started before adding fueling items. The first being a lift pump such as the airdog or the FASS which already stated you have a raptor. So the next thing you need is gauges ( boost, pyro, fuel pressure) most importantly is the fuel pressure because low fuel pressure is what kills your injection pump the quickest. So basically what happens inside your injection pump is that when there is not enough fuel to feed the pump so the fuel cavitates inside the pump therefore burning the pump up prematurely.
Old Dec 31, 2010 | 11:56 PM
RAW's Avatar
RAW
true, that is a mechanical failure of VP44's. Most of the time a VP has electrical failures from low fuel pressure. The VP44 uses fuel to cool the electronics in it, low fuel pressure is low flow, low flow removes less heat.
