overflow valve install
Old Dec 31, 2010 | 06:55 PM
lodal cummins's Avatar
Default overflow valve install
so it appears you need to grind off some of the intake manifold to get the valve out as it looks like not enough room to un thread. true or false? plus do you need to pump the lift pump after install? thanks and HAPPY NEW YEAR!!!!!!!!
Old Dec 31, 2010 | 07:55 PM
12vcummins96's Avatar
no need to grind the head and no pumping the fuel pump
Old Dec 31, 2010 | 08:12 PM
ok sounds like a easy one thanks a bunch!!!!!!!
Old Jan 1, 2011 | 07:07 AM
Apmcrx's Avatar
Yeah just slide it out. you gotta tug on the line a little bit, but it comes right out. hold onto that bottom washer! unless you have replacements (recommended)
The first time I did it, I pulled the intake manifold and loosened the 10mm retaining bolt/clip below it (about halfway back the pump) thinking it would loosen up the line a lil bit, but it didn't make any difference, it's a hard line, so don't waste your time doing that. Just FYI...
Old Jan 1, 2011 | 03:16 PM
ozzking93's Avatar
i just replaced mine, its a simple 10 minute job if you are wrench searching, main thing is if you dont have replacement washers DONT LOSE THEM,it took me ten minutes to do it after i gave up looking for a wrench and just grabbed an adjustable.
i loosend it grabbed the bottom washer,then moved the line up and pulled the thing right out, then put the other one in slid the washer on and stick it in and tightend it down.
didnt fix my starting problem though. but i hope it fixes whatever problem your having.
Old Jan 1, 2011 | 06:08 PM
its always a good idea to have 14mm sealing washers on hand before doing anything with the fuel system
Old Jan 23, 2011 | 05:33 PM
noizykrikit's Avatar
the overflow valve takes a 19mm wrench just pulled mine out today
Old Jan 23, 2011 | 07:14 PM
c12vpwr's Avatar
on my 96 it was easy it took 10 min to do on my 95 i had to grind it idk why it didnt come out the same on it but would not work
Old Mar 29, 2011 | 01:48 PM
vectorboy_99's Avatar
My uncle is having the same problem on his 95
RA113024
Mar 13, 2016 07:42 PM
jeremiah1
Jul 21, 2015 06:35 PM
Baradium
Mar 9, 2015 07:15 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
