crappy AAM axle u-joints
Old Dec 30, 2010 | 11:00 PM
crusty's Avatar
Default crappy AAM axle u-joints
2003 and up uses crappy u-joints machined .010 undersized so good u-joints (spicer) can't be used to replace them. anybody find a good replacement for these sorry joints.
Old Dec 31, 2010 | 01:52 AM
cumminscontrol's Avatar
got mine from napa, have the grease fittings, they work fine.....$45 each
Old Dec 31, 2010 | 06:14 AM
oldgrey90's Avatar
spicer does make a replacement for axle joints. a 5-806 spicer was used up to 02 those are a 1480 wheel joint. an aam is a 1485 wheel joint thats why they are .010 different. the spicer part number for the aam ft is a 500...... number i cant think of it off the top of my head......i will have to look when i go to work today.
you bring up a good point about the .010 because the same can be said about the drive shaft. a 1480 joint is .010 wider from outside of cap to cap then the 1485 aam driveshaft. thats why when you put replacement joints in from napa or where ever the snap rings are bulging way out and tons of ppl say there shaft then has a vibration.......for some reason thats kinda hit or miss. sadly the only correct replacement joint for the driveshaft is the aam joint.
aam axle joint spicer replacement part#5006831
Old Dec 31, 2010 | 03:07 PM
crusty's Avatar
will a driveshaft from 02 fit an 03?
LawdawgSHPD
Aug 21, 2015 06:23 PM
99RAMS
Tire, Wheel & Suspension
Jan 25, 2015 11:31 PM
KYLEBOY
Jan 18, 2015 06:36 PM
Dec 19, 2014 02:30 PM
natenel1
Oct 26, 2014 03:09 AM
