nv5600 swap
Old Dec 30, 2010 | 07:34 PM
bigbadcummins91's Avatar
Default nv5600 swap
im hoping for some insite on swaping an nv5600 out of a 03 common rail ho 4x4 in to my 96 2wd dually it is an automatic i know i have to change the output shaft to a 2wd drive one but the main main thing is does anyone know the gear ratio in the nv5600 cuz the 12 valve is going to be a daily driver or a toy im not sure just yet but im rebuilding the rear end and dont want to put one thats too tall for the 1st gear thanks
Old Dec 30, 2010 | 07:44 PM
Cant give you any info on the swap but there is some good info here that might help:
Ram NV5600 specs
You will be fine with the OEM 3:54 gearing - especially since its a 2 wd.
Old Dec 30, 2010 | 08:55 PM
https://www.dieselbombers.com/dodge-...ion-notes.html
Old Dec 31, 2010 | 04:38 PM
what u posted said that the nv5600 was for model years 99-01 im get my brothers 6 speed out of his 03 common rail he said that its a 5600 cuz its the high output but the others are the g56 do you know which it is?
Old Dec 31, 2010 | 07:32 PM
The NV5600 should be the same. Dont quote me on this but I believe you are correct - the NV5600 was for the HO trucks, there was a NV4500HD for the standard output trucks and the G56 came out later than 03.
You should be ok.
Old Jan 1, 2011 | 10:04 AM
ok and the hydro's and pedals all should bolt up on to the 12 valve?
dpgcummins12v
12
Apr 20, 2015 10:24 PM
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
SixSpeed
Jan 11, 2015 01:41 AM
CumminsMan2.0
Dec 11, 2014 04:57 AM
Jgloveracob
Nov 16, 2014 07:27 AM
