Blow by
Old Dec 30, 2010 | 04:26 PM
8roughneck8's Avatar
Default Blow by
I have an 06 Dodge that has some blow-by. Some have told me that it will have some blow by and some have told me I need an engine rebuild or remanufactured replacement. It has 118k miles, an oil leak from the front gear cover that I need to fix, and my wife is freaking out . It runs fine, blows a little more black smoke than it used to, idles a little lower (600), and still does everything I need.
My question is how much blow by is ok? If you take the oil cap off when its running, you can feel it on your hand. I need to know if this is acceptable for a while, or if I really need to fix it now?
Thanks
Eric
Laramie, WY
Old Dec 30, 2010 | 04:47 PM
Whit's Avatar
Site Mascot
is your crank case vent plugged?
Old Dec 30, 2010 | 04:59 PM
crank case vent = blow by tube???? The blow by tube is not plugged
Old Dec 30, 2010 | 05:05 PM
Whit's Avatar
Site Mascot
so when its idleing the tube blows plus out the oil cap hole if cap removed
Old Dec 30, 2010 | 05:28 PM
83cucv1028's Avatar
take it to a good diesel mechanic and have them do a compression check, my 04 had alot of blow by. it looked like a train when i took off my oil filler cap and it was because the rings in #1 and #6 gave up the ghost. how much oil is it using?
rollover
May 5, 2015 07:33 PM
EasTxOilfields
18
Apr 2, 2015 01:51 PM
jedder21
Mar 7, 2015 09:47 PM
Nov 10, 2014 08:10 AM
CumminsCrazed
Price Quote - Request A Price
Oct 13, 2014 02:35 PM
