Starting strange
Old Dec 30, 2010 | 01:37 PM
wpg6.5's Avatar
Default Starting strange
For about 2 weeks now everytime i start my truck it starts strange. when i start it, it bumps up to about 500rpm then slowly rising to about 650 like normal. this is where the weird part starts. it then continues to rev up about another 100 rpm and then begins to sputter/chug. This only happen on cold starts (-10 ish) im confused. i thought it may be i cracked the block= fluid in and possibly improper combustion. but now not sure kuz it used now coolant. glow plugs are all brand new so im not sure. my other question is would too much diesel additive do that. if not then something is going. drives and everything else fine. just cold start.
Old Dec 30, 2010 | 02:26 PM
Crazy's Avatar
that right there could be one of the problems how much coolant are you using
additive should not do that if anything should make it run better
maybe got some bad glow plugs
sure it smoking when you start it what color and what it smell like
Old Dec 30, 2010 | 03:44 PM
wpg6.5's Avatar
i ment to say it used no coolant. it could be the plugs if im really unlucky. it always puffs out a bit of black then goes to whiteish kuz its cold out. its only really pumped out smoke a bunch once. smells like diesel. no antifreeze smell. i havent started it yet today so ill see if its still doing and and try and explain best i can what its doing.
Old Dec 30, 2010 | 03:51 PM
Crazy's Avatar
make sure you are getting power to each glow plug
i see you say -10 deg out you may want think about pluging for about 3hrs before start at them temps
Old Dec 30, 2010 | 04:26 PM
wpg6.5's Avatar
i do about 90% of the time. unless its only off for like an hour or 2 and outside temp. How long can a 6.5 last with a cracked block or using coolant.
Old Dec 30, 2010 | 04:43 PM
Crazy's Avatar
not long
wouldn't try driving very far all if you think crack block
if you think that what wrong i would be pulling it apart and see what can be save
if it drive fine and not loosing coolant and and getting any smoke i wounldn't think crack block just cold start problem
Old Dec 30, 2010 | 10:00 PM
wpg6.5's Avatar
still not sure on the using coolant yet still might be hardly using. but it has the pressurizing after cold start. havent started it yet. just plugged in. unfortunate thing is here its about -30C and im a student so i dont have a whole lotta time or money. im maybe considering a 6bt or 4bt swap as soon as summer comes and try and do it on the cheap
So just checked fluid on level surface. has gone down quite a bit. about an inch or so. as for starting. that didnt really workout for me, too cold i think. starter didnt kick in first time, then every other time it turned once or twice and kicked out. finally started followed by a fair amount of sputtering which i assume is from the excess fuel so cant really judge if its burning coolant. exhaust smelled as per usual and it ran great after she warmed up a bit. very confused.
Old Jan 1, 2011 | 09:44 AM
zielinski.family's Avatar
Sounds like air in fuel line possibly. Check all the return lines. If not soft replace. Check the T-valve as well. Mine acted some what like that come to find out the T-valve had a loose clamp and would allow air to get in.
Old Jan 1, 2011 | 12:59 PM
wpg6.5's Avatar
that may be it. ill check, the only thing i cant rule out in my head as just some 6.5 little issues adding up is the pressurizing or the surge tank after cold start. does anyone else know this to be true of cracked blocks.
Old Jan 1, 2011 | 01:04 PM
Crazy's Avatar
how hard is top hose get when you it and if you are building pressure in the surge tank you have bad head gasket these motor know blow head gaskets
