Whats the best Turbo upgrade that is a direct bolt on?
Old Dec 30, 2010 | 12:19 PM
jeffandjess4806's Avatar
Default Whats the best Turbo upgrade that is a direct bolt on?
I want to get a better Turbo what is the best bolt on no mods Turbo for our gen 1's
My truck is a 92
Old Dec 30, 2010 | 06:03 PM
hiboy_76's Avatar
i'm under standing that your truck is stock right? then an hx35 is pretty good
Old Dec 30, 2010 | 06:09 PM
Whit's Avatar
Site Mascot
correct......make sure its not the HY......get the HX35
Old Dec 30, 2010 | 06:15 PM
hiboy_76's Avatar
yea very true, the hy's only have a 9cm exhaust housing i think
Old Dec 30, 2010 | 08:14 PM
I am getting a denny t pin and a 3200 spring and straight pipe and tweak the pump
Old Dec 31, 2010 | 07:40 AM
hiboy_76's Avatar
it still wouldnt be a bad turbo, the compressor side is gonna be the same on your stock turbo and the HX35, they're both 56mm inducers. You could buy a compressor upgrade for the hx35 if you wanted to, but either way it will spool up faster than the h1c.
Old Dec 31, 2010 | 08:36 AM
This look ok > UPGRADE HX35W HX40W DIESEL TURBO CHARGER CUMMINS NEW - eBay (item 130469585535 end time Jan-04-11 14:13:43 PST)
What about a HX40
Old Dec 31, 2010 | 08:07 PM
JBradley500's Avatar
the best upgrade thats a direct replacement would be a fresh turbo with 60mm compressor wheel upgrade and 12cm exhaust housing.
Old Jan 7, 2011 | 09:06 AM
1stgen350's Avatar
Default ve44 pump
what year is it
m@h timing spacer ? first time i have heard about it
Old Jan 7, 2011 | 02:09 PM
The_Head's Avatar
It's not a direct bolt on.
