12v Cummins 47re to NV5600 conversion
Old Dec 29, 2010 | 11:20 PM
WILDKING's Avatar
Default 12v Cummins 47re to NV5600 conversion
Does anyone know how this can be done?
Old Dec 29, 2010 | 11:42 PM
blazier18's Avatar
wat are u tryin to figure out?
Old Dec 29, 2010 | 11:51 PM
WILDKING's Avatar
i need to know what year 6 spd i should look for?
Old Dec 30, 2010 | 12:15 AM
blazier18's Avatar
tough question im guessing 98.5 to 2002. ull also need an a spacer plater or something like that
Old Dec 30, 2010 | 12:35 AM
kazairl's Avatar
01-05 I believe. It might be 04. Pre 01 5600 had smaller input shafts and some other undesirable features. You'll also need a spacer for the starter and a crossmember from a newer 2nd gen. I'm not sure when they started using the newer style crossmember that had 2 slots of holes for both trannys. Probably 98 or 99.
The 5600 is about 6" longer so your going to need some driveshaft work too.
Old Dec 30, 2010 | 01:19 PM
big willy's Avatar
i was told that the 2008 6 spd's will bolt up not 100% sure on that so some one correct me if that's not true but that's just what i was told when i got my tranny rebuilt
Old Dec 30, 2010 | 01:22 PM
kazairl's Avatar
The cross member has to be modified to accept a g56.
Old Dec 30, 2010 | 08:08 PM
WILDKING's Avatar
Default thanks fellas!
i thank you all for your comments!
Old Dec 30, 2010 | 08:21 PM
blazier18's Avatar
if u have the chance to get one i say go for it. i can help u a little bit i just did the swap but to a 5 speed
Old Dec 30, 2010 | 08:27 PM
Whit's Avatar
Site Mascot
here is some good valuable info
https://www.dieselbombers.com/dodge-...ion-notes.html
