Right Hand Side Headlight
Old Nov 19, 2007 | 02:00 AM
greyghost2's Avatar
Default Right Hand Side Headlight
well, had a headlight go bad and replaced it and low beam will still not work cluster still says lamp out any suggestion the old bulb was bad .........
Old Nov 19, 2007 | 11:36 AM
DB Admin's Avatar
Banned
Swap your bulbs left to right and see what happens
Old Nov 19, 2007 | 11:50 AM
Johnny Cetane's Avatar
You need to see if you're getting power to the socket. My take on the wiring schematics is that if the Integrated Power Module isn't supplying the voltage then it itself is at fault. It sounds like there are scan tool specific diagnostics to check this component if it is not working. You may be looking at it's replacement or reprogramming. (If they reprogram them.)
Here's the wiring for the right side and Dodge's flow chart for checking headlight problems.
Old Nov 19, 2007 | 11:57 AM
DB Admin's Avatar
Banned
Old Nov 19, 2007 | 01:55 PM
Johnnys just showing off with his fancy online manual...
sujumptd
Audio Equipment/Electrical
Jan 16, 2016 07:40 PM
Rigman
Jun 19, 2015 02:15 PM
carid
Group Buy
Apr 16, 2015 08:38 AM
suzan
Dec 2, 2014 03:03 AM
