Engine Needed... Looking for Help In or Close to Tulsa OK
Old Dec 29, 2010 | 02:06 PM
thewanman's Avatar
Default Engine Needed... Looking for Help In or Close to Tulsa OK
I just had an injector issue in which it has terminated my 2003 5.9 Cummins. I am looking for any assistance on a engine rebuilder in Tulsa Ok.
Any Help would be greatly appreciated....
Also, Has any ever dealt with the following folks:
The Horsepower Shop in Pa.
See the web link below...
03-07 5.9L DODGE 24 VALVE DIAMONDBACK CUMMINS ISBe 500HP+ CRATE MOTOR -
THIS 5.9L DODGE 24 VALVE DIAMONDBACK CUMMINS ISBe COMMON RAIL CRATE MOTOR STARTS WITH A HAND-PICKED AND FULLY-TESTED SEASONED BLOCK. THE BLOCK IS BORED, HONED AND MACHINED TO ACCEPT THE BALANCED ROTATING ASSEMBLY. ALL ENGINE COMPONENTS ARE INSPECTED TO ENSURE STRENGTH AND RELIABILITY.
THIS ENGINE WILL MAKE 500HP+ and 1050F T/LBS OF TORQUE+
THIS ENGINE WILL ALSO COME WITH A FREE 120HP ELECTRONIC MODULE
03-07 SEASONED CUMMINS 24 VALVE
ISBe COMMON RAIL BLOCK
CRANKSHAFT WITH STD. ROD AND MAIN JOURNALS
RODS ARE SIZED WITH NEW PISTON PIN BUSHINGS
NEW FORGED ALUMINUM PISTONS
NEW PISTON RING SETS
NEW HIGH PERFORMANCE FLAT TAPPET CAMSHAFT
NEW HIGH PERFORMANCE LIFTERS
CLEVITE ROD, MAIN AND CAM BEARINGS
NEW FREEZE PLUGS
NEW FLUID DAMPER
NEW INTAKE AND EXHAUST VALVES
NEW HIGH PERFORMANCE VALVE SPRINGS
NEW 100HP OVER STOCK INJECTORS
REBUILT HIGH VOLUME CP3 INJECTION PUMP
NEW HIGH VOLUME OIL PUMP
NEW ARP HEAD STUDS
ALL NEW GASKETS AND O-RINGS
NEW VALVE COVER GASKETS
NEW CAM SENSOR
NEW CRANKSHAFT SENSOR
NEW HIGH VOLUME WATER PUMP
3/8 CHROMEMOLY PUSH RODS
NEW TURBO WITH 66MM COMPRESSOR WHEEL
THIS ENGINE COMES COMPLETE WITH 2 PIECE MANIFOLD. YOU WILL NOT FIND A MORE DETAILED AND PROFESSIONALLY ASSEMBLY ENGINE ANY WHERE.
WE ONLY USE THE HIGHEST QUALITY PARTS IN OUR ENGINES.
THERE IS A $1500.00 CORE CHARGE ON ALL OF OUR DIESEL ENGINES THAT WILL BE REFUNDED WHEN A REBUILD-ABLE CORE IS RETURNED.
WE ALSO MAKE A STAGE 4 & 5 ENGINE THAT MAKES OVER 650HP+.
IF YOU NEED ANY INFO OR JUST PARTS FOR YOUR ENGINE FEEL FREE TO EMAIL.
ALL OF OUR ENGINES CARRY A 12 MONTH WARRANTY. WE WILL EITHER REPAIR OR REPLACE YOUR ENGINE FOR A TIME PERIOD OF 1 YEAR FROM THE DATE OF DELIVERY PROVIDING THAT THE ENGINE HAS NOT BEEN MALICIOUSLY DAMAGED.
burndiesel
10
Feb 7, 2023 01:15 AM
klein444
Jun 20, 2015 11:48 PM
ctjkelley
Jun 3, 2015 06:01 AM
mcclusk
Feb 21, 2015 09:50 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
